View topic - On the scrounge!
On the scrounge!
This forum is for news and information regarding the North East branch and it's events.
On the scrounge!
Postby trevor9 » Tue Oct 27, 2015 8:08 pm
Going to replace the clutch on my T3 Cali in the next couple of weeks. If anyone has the socket to remove the nut holding the splined clutch gear on the gearbox shaft and the tool to compress the clutch plates I would be most grateful if I could borrow them and return them together with some 'liquid' remuneration!
thanks
Trevor (Durham City)
trevor9
Non MGCGB Members
Re: On the scrounge!
Postby iandunmore » Wed Oct 28, 2015 11:36 am
If you cannot get the castellated socket buy a new nut and knock it off with a hammer and screwdriver.
Replace the same way.
I do not remember any other special tools.
Be vary careful lining up the 3 clutch plates though.
And if you can drop the engine nose first into a car tyre or spare wheel, makes it all easier to work on.
Lil'Breva and a Bellagio.
User avatar
iandunmore
MGCGB Member
Postby Phil Gough » Wed Oct 28, 2015 5:44 pm
A heathen after my own heart :D , that's how I do it as well, but use a stout piece of flat bar instead of the screwdriver method, (use your new splined boss to align the clutch plates before you fit it to the box)
User avatar
Phil Gough
MGCGB Member
Postby Mike H » Wed Oct 28, 2015 8:09 pm
The gearbox input splined boss itself may be used as a clutch plate centring tool. The flywheel has threaded hole up the middle for a bolt on which you can in turn centre the boss.
I'm assuming the Cali is baiscally same as other Tonti's...
"No matter how fast light travels it finds that the darkness has always got there first, and is waiting for it."
User avatar
Mike H
MGCGB Member
Postby trevor9 » Tue Nov 03, 2015 8:28 pm
Thanks for the replies. I pick up a deep spline clutch at the weekend so will have a clutch centre to use to line the plates up and make up a tool to compress the clutch springs. Now need to sort a long bolt or threaded rod to screw into the end of the crank. Can anyone confirm what thread size it is and where I might source one. Its an M12 but the pitch size is different than the norm
thanks
Trevor
trevor9
Non MGCGB Members
Postby Mike H » Tue Nov 03, 2015 11:53 pm
Aren't there 8 coil springs with the 8 bolts through them? So the bolts are the 'compressor', or rather, undo them and it all falls apart.
EDIT: I think you have to watch out that the rear flywheel disc goes back in the same position that it was when it came off, to keep correct balance of the flywheel. So mark its position relative to the main flywheel before taking it off. This part has the starter ring gear on it IIRC.
User avatar
Mike H
MGCGB Member
Return to North East Branch
Who is online
Users browsing this forum: No registered users and 1 guest
User Control Panel
Who is online
In total there is 1 user online :: 0 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
Most users ever online was 174 on Wed Apr 06, 2016 5:06 pm
